WINDON LEADER - SINGLE SPLICE
After the long discussions in thread
I made up a sequence of pic's of how to make a windon for casting using a single dacron length. The motivation why and just how strong the single Dacron is vs your mainline is discussed at length in the post.
70cm 80lbs High Vis Cortland Dacron
Insert the latch hook 2.5cm below the end of the braid and thread though 2.5cm away from the short end
Exit the Short dacron
Hook the main length of Dacron and close the latch
Pull the main dacron through the 2.5cm and then slide the 2.5xm over the main length and pull tight, set the length of your loop by pulling the main length through the 2.5cm sheath
Make a Tanaka Splice by taking the tag end back and forward through the main length, minimum 3 times, recommended 5 times.
Now insert the latch hook 1cm below the length of the tag end, thread it up to the splice and pull the tag end inside and so that it is now hidden inside the main length
Your completed loop section
Split the leader line about 4-5cm from the end and make a long thin end that is easily bent double
Easily bent double
Insert a long latch hook all the way down the main dacron from the splice till is is exposed
Hook the thin doubled over end of the leader and pull it through the dacron and out just below the splice. I sand the leader lightly to help the grip of the dacron on the nylon of the leader.
The thin section is now trimmed off and the leader pulled back into the dacron.
The frayed end of the dacron is then trimmed to make for neat serving.
Very thin super glue is applied to the outside of the Dacron, it'll immediately seep through and adhere the dacron to the nylon (4-5cm from the end of the nylon)
Start the serve before the superglue dies and the serving braid is immediately in place (tip - wet the end of the serving braid and it sticks immediately to the dacron)
Locking system on the jig, allowing for hands free operation with the leader pulled very tight ensuring the leader is locked in place.
The serving tool is set so tight that the windon winds up at least 5 winds before the serving tool releases braid to the bind
12 seconds later and the full serving is done all the way to 1cm over the nylon
6 x half hitches
followed by a hitch with 6 turns inside
and pull up tight and trim of flush to the whippings
Coat with thin Super Glue and it will seep through the braid all the way to the underlying dacron and bind the whole lot together
Finish off with a low heat, heat shrink that will prevent the whippings from unraveling through constant use
Join to your mainline using a cats-paw loop to loop connection or the alternate catspaw of Reefman, es[pecially with 130 and 200lbs Dacron
This complete 1.5mm windon was made in less than 10 minutes (even with taking the photographs)
The braid used for serving was 80lbs jigging braid and was used purely to make the photography easier, I use a 20lbs dyneema to serve my fishing leaders.
neilg
Good tutorial ... !
I make it about the same, but don't have your fancy tools Enigma, I use Piano doubled wire to thread the dacron through itself and work the mono in by hand. My only fancy tool is the fly tying bobbin to work it off at the end.
Personal choice
I don't do the glue or the heatshrink. Used to do it that way but stopped a long time ago.
The way you make it is BULLET PROOF !
AviL
Good post Enigma - very well presented tutorial.
Quick question:
Does the Superglue not become hard and brittle which can easily break?
Is the heat shrink not hard and how does it pass through the eyes? Does this not cause damage?
I use a bimini to tie my leader onto my mainline...
*Guys, if I get it wrong, please forgive me, I am a little new to all this...Thanks
Quick question:
Does the Superglue not become hard and brittle which can easily break? never had an issue with this, before I used the shrink I sometimes had that from continuous use, 100 or more casts the a half hitch or 2 would come undone and all I would do is drip another drop of SG on and sorted
Is the heat shrink not hard and how does it pass through the eyes? Does this not cause damage? The shrink tube I use is super soft and pliable and with it on you don't even hear the knot going through the guides. Main use of the shrink is to smooth the knot and at the same time protect the knot
I use a bimini to tie my leader onto my mainline... thats fine for leaders under 1.2mm. From 1.2 and up it gets cumbersome and after 1.5mm you are guaranteed to knock out a guide ring every 2nd or 3rd cast, we also use a bimini and then connect the loop of the windon to the loop of the bimini with a loop to loop (7 times through) this is what is known as a Cats-paw (check under the knots at the illustrations of Reefman)
*Guys, if I get it wrong, please forgive me, I am a little new to all this...Thanks that's what we're all here for to share and learn from each other,.............THE ONLY DUMB QUESTION IS THE ONE NOT ASKED..............
tkei
Enigma, where do you get that heat shrink? I can only get the black one here in el and heat it with hair dryer, but the walls are quite thick so not too smooth through the guides.
Trophy
Hiya Enigma,
Excellent post!
I thought I liked the Bling Bling...you take the CAKE!!
I'm sure nobody can go wrong with making the single splice wind-on going forward.
Now all they have to do is collect all the tools and toys you use! LoL
Trophy wrote:
Hiya Enigma,
Excellent post!
Those of you who know Carp fishing will recognise all those goodies as Boilie fishing tools so not to cost an arm and a leg.
What I didn't show is I simply use a darning needle to make the tanaka splice.
If you cannot get latch hooks at your fishing store then you can find them online at www.rratlapiangling.co.za (mr Fish) and speak to Jan he'll sort you out quick, quick)
Or have a look at your local haberdashery (Naaldwerk winkel)
Instead of the serving tool you can use a fly tying bobbin to hold the thread.
steve m
Enigma wrote:
Trophy wrote:
Hiya Enigma,
Excellent post!
If you cannot get latch hooks at your fishing store then you can find them online at http://www.rratlapiangling.co.za (mr Fish) and speak to Jan he'll sort you out quick, quick)
I also have one of those boilie tool things they help a lot! mine cost me all of like 15 rand..
Upgraded the process.
4 stitch Tanaka splice forming a small loop. Small loop for a casting windon minimizing the chances of the dacron wrapping on a guide
Tanaka splice done and tag end of 3cm into the dacron.
The Daho needle ID 1.35mm
Needle threaded through the Dacron and easily through the middle of the tag (inside) and out close to the Tanaka splice
Here is the finished product in terms of the loop. Double dacron over the nylon leader, followed by a very short double dacron into the Tanaka splice.
The shorter distance means no chance for the dacron to wrap around a guide.
