The contention that South African rods are too stiff for pendulum casting and that the weight ratings of your rods is inaccurate is not entirely true.
THANK YOU SO MUCH....... HAVE ABSOLUTELY NO IDEA WHO STARTED THIS RUMOR
Neels Mosterd won the WA Casting on aggregate total last year and his top casts were over 200m using the Exage 1468 fitted with a Akios Rocket.
Ratings are inaccurate when measured against typical International Ratings.
For example the 7ounce P3 by Blue Marling is rated for 7oz but comfortably casts a 7oz and a Yellowtail (NZ Kingfish) head.
What about something like an Assassin Heavy HMG though? Will that work well with a pendulum cast or the Absolute Shark or Shark Extreme Heavy?jonnovet wrote:
Why on earth such big tackle my clients from Europe ask me at Gamtoos. They try their 0.30mm on a SL20..... cant get a sinker to sit in that wash......
Eventually gets a sinker to sit, after his cast and wade he has maybe 50m of line left on his reel, picks up a 15kg Hound and is stripped to the drum in no time and ends up wading neck deep on more than one occasion and eventually lands his fish.
What would have happened if it was a 30kg kob or 15kg Steenie....... stripped and empty.
Wow...I raised this issue way back. To date I haven't seen anyone using the pendulam cast.
nope, off the ground is good enough.
it looks like it can work, but hook is quite deep into the bend.willem wikkel spies wrotenope, off the ground is good enough.
If you like OTG casting, you will enjoy Gemini Splash down bait clips.
